DTMF decoder using microcontrollers?!
sayfollah
Newbie level 6
Newbie level 6
dtmf decoder +op amp
does anybody have an idea how to make a microcontroller (pic, atmel..) decode DTMF signals without the use of an external decoding chip?
can u help?
dtmf decoder
you couldnot, you need filters to decode DTMF tones, which is too difficult to be built using MC assemply, it's better to use 8870 DTMF decoder
microcontroller with dtmf decoder
i've done creating DTMF GENERATOR using PIC and MATRIX keypad. I've used PROTON+ PICBASIC COMPILER.maybe there's a way in decoding the output of the DTMF!ü
notes on mt8870
Why you are not searching the web ? ))
mt8880 application
thx artem, that helped me much..
by the way, you see iam new here, how can i tell that you helped me?
pic18 dtmf decoder
It does not matter to me. ) Just help others.
And of course, micrchip has very good Application notes and may be this one concerns subject as well :
DTMF Detection Using PIC18 Microcontrollers
mt88xx and pic
Use MT8870 is the best. Why do you want to make it so hard?.
dtmf decoder in microcontroller
Hi;
you also can search the web for Goertzel algorithm.
Regards,
Davood Amerion
dtmf detection using microcontroller
Hi
SI-LABS have an app not for the 8051Fxxx for decoding DTMF signal all written in C language
www.silabs.com
All the best
Bobi
microcontroller dtmf
bobcat1 said:
Hi
www.silabs.com
All the best
Bobi
About what application you talk? AN122 - here there is only outputs DTMF tones!
Added after 20 minutes:
Davood Amerion said:
Hi;
Regards,
Davood Amerion
here there are good description of decoding DTMF tones:
dtmf decoder+microcontroler
Suppose that a telephone (A) calls another (B). So how to know when the B picks the handset up?.
I am using MT8870 to decode numbers pressed by user. How to know when thi B picks handset up by using a MCU such as ATMEGA8515L
//Sorry for my terrible English!
dtmf decoder microcontroller c
use MT8880
daa mt8880
shmily said:
use MT8880
My dear, I have just skimed the Datasheet of MT8880 as well as MT8870. But it has no pin that says when the telephone B pick the handset up. If you could do this with MT8870 or MT8880, pls show me in detail.
Thank in Advance
dtmf decoder using pic microcontroller
My information in this case...
That fesility is provided by the telephone company(Exchange)
For public call office lines they are providing this feature and based on this signal the call metering system starts reading when the other party picks up.
It is done by the polarity reversal of lines I think..
I have no much idea.
but is this a clue?
please post if you find a way without the help of telephone company.
Thanks
picstudent
decoder dtmf radio control
Ok, contineu our story. Someone have told me that when the telephone B pick handset up, the Voltage being on Telephoneline wil drop dramatically from 40V to a lower level of electric potential. Isn't it?. If so, how to recognize this by microcontroller?
dtmf decoder picbasic
Hai
This you are talking about the case of our first telephone (which you used to call telephone b.)
When your phone is in Hook the DC voltage will be around 48volts(+-)
When you pick up your phone the DC voltage present in the line suddenly drops to 12v or 15v range.(Varies from company to campany slightly)
The company provides a high impedence line and when telephone circutary loads that circuit it drops to 12 volts and you get dial from exchange.
If this is your situation you can detect it by a simple op amp comparator.
but my problem is how to detect weather the otherside picked or not.
:cry:
with regards
picstudent
Picstudent said:
If this is your situation you can detect it by a simple op amp comparator. But my problem is how to detect weather the otherside picked or not.
:cry:
with regards
picstudent
Ok, my problem is like to you, weather the otherside picked or not.
It seems to be harder when you call a Mobilefone instead of a home phone.
Hai
I dont think it makes any diference weather we called Mobile or landline.
After we dial a number I think rest is controlled only by Exchange.
So that system have to pass us some information.
Let us wait for other Guys responses.
picstudent
Why not listen to ring signal heard through the speaker?
