megantt
hello everyone , working zebronics power supply 450 watts , 5v ,3.3v giving short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms at 3.3voutput, 51 ohms at 5v output, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
how this happend - i was putting a bad sata cable extension which blew the 12v/5v diode(not sure) in hdd pcb ( repaired it -working now) and made this short in psu , how to remove the short , thank you .what problem this short can cause to mobo and hdd ? i am not sure this short caused hdd 5v or 12 v diode break or the bad hdd sata cable caused this , but when the hdd gone bad , the other 2 hdd were working normally and computer was still power on , i checked the power cables black wire(ground) short with red wire (5v ) , then short with 3.3v orange wire , i know this is not normal , so i dint put this psu again in my computer ,i wana remove the short, guide me , thank you
