saminda
Newbie level 6
- Joined
- Jan 11, 2012
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Dombivli, India, India
- Activity points
- 1,386
I have 45 w inverter .when I connected to mobile charger or any small instruments , charger's led lites up and gone off immediate.I have checked its output ,its huge 630vac and 227vdc .please help me I want to repair that at home
t12 =c557,burnt comonent is regulator LM317.its working properly with 14v charging voltage.
it is local made.what will be the transformer's rating
One important point here.I have checked its output ,its huge 630vac and 227vdc .
Can you explain why this is so?One important point here.
If you check dc voltage by mutimeter set to AC range, it will show double voltages.
as for ac your meter does not have true rms option it reads peak volts.
