433mhz interfacing 89s52
mishra12
Advanced Member level 2
some where left alone
dear friends
i am able to transmit data connecting txd and rxd pins directly along with gnd wire but when i connect to system using tx and rx no transmission occurs and my modules are ok where i went wrong ?i kept baud rate as low as possible 300bps . i know the problem with data transmission through modules my codes are correct .
here is my circuit but can i transmit in shift register mode encoding in manchester code how i need sample code
  • edaboard.rar
