A practical FR4 laminate thickness for microwave circuits with SMD components is probably 0.8mm. A 50-ohm microstrip line has a width of about 1.5mm and about 0.2dB/cm of loss at 5.76GHz. Therefore microstrip lines have to be kept short if etched on FR4 laminate. For comparison, the FR4 microstrip losses are about three times larger than the microstrip losses of a glassfiber-teflon board and about ten times larger than the losses of teflon semirigid coax cables.
Although FR4 laminate losses are high, resonators and filters can still be implemented as microstrip circuits. Considering PCB etching tolerances and especially underetching, both transmission lines and gaps in between them should not be made to narrow. A practical lower limit is 0.4mm width for the transmission lines and 0.3mm for the gaps.
