using MMIQ-0416HSM as upconverter
yefj
Advanced Member level 5
Hello, I want to use MMIQ-0416HSM for upconvertion.
The only converstion loss data I see is for downconvertion.
How can I see the conversion loss in upconversion mode.
Thanks.
Hello , The plot below says what is the conversion loss in downconverting mode.
What plot do you mean?
Thanks.
Hello Volker, Yes I see it.
could you say if the compression point fo the upconversion is the same for downconvertion?
I cant see compression points for upconversion.
Thanks.
LaTeX Commands Quick-Menu:
