TLV1811 comparator setting into push pull mode
yefj
Advanced Member level 5
Hello,I have the following TLV1811 component which is used as comparator.
In the datasheet on the headline they say it could be push pull or open drain output.
If the TLV1811 will be set as open drain then ill have to put pullup resistors.
How can I know that my TLV1811 is pushpull?
Thanks.
https://www.mouser.com/ProductDetail/Texas-Instruments/TLV1811LDBVR?qs=rQFj71Wb1eX09MzTfpxERg==
https://www.ti.com/lit/ds/symlink/t...=https%3A%2F%2Fwww.ti.com%2Fproduct%2FTLV1811
Hello, When I want to choose TLV1811 component I have difference of the last letters in the name.
I have DCKR and DBVR.
What is the difference between them regarding footprint sctructure?
Thanks.
In the data sheet they say DBV and DCK are the same footrpint but they dont mention the last letter "R"
Pin 2 is output and Pin 5 is V+.
Where do you see output at pin 2?
The shown schematic symbol is apparently showing TLV18x1L type with reversed supply, output still at pin 1.
I would b.t.w. suggest larger SOT23-5 (DBV) unless you love soldering under microscope.
LaTeX Commands Quick-Menu:
