xchcui
Member level 3
Hi.
I was trying to adjust the output of this LM2596 3 POT to 1.8VDC and 20mA. The voltage potentiometer(left pot)was not a problem to be adjusted to 1.8VDC,but i couldn't adjust the current potentiometer(right pot)to 20mA. The instructions says to connect the output to ammeter(dmm)at 10A scale and adjust the current(without aload),i did that,but even if i am turning counterclockwise the screw all the way left,the current is not get lower than 20mA(while the voltage is setted on 1.8v).The only way to get the 20mA was to raise the voltage above 1.8v and then the current potentiometer let me to decrease the current to 20mA.And if i want to decrease the current more,i have to increase the voltage more.Since that,i can't adjust the 20mA current to the voltage that i would like to adjust(1.8v).
Why does it behave like that?Is it normal?How can i achieve the 20mA at 1.8V?
Thanks.
