antonkurka
Newbie level 5
Hi
After I discovered errors in my project when
using IP-Coregen(6.1) FloatingPoint components, I have a very simple test for just floating point multiplication.
after compilation, the entire multiplication block was removed in the MAP report.
see attachment
This is clearly an error in my version ISE14.7
My tool: ISE 14.7(nt) version P.20131013
Is there a newer/older ISE version in which this error does not occur in IP-Coregen.
Porting to Vivado is out of the question because the IP components are completely different and would therefore require very large changes in my project
Pleace can You help me, I don't know where to look any further.
: TestOutp = InpA * InpB
Loadless block "cmulFP1/blk00000001/blk00000024" (XOR) removed.
The signal "cmulFP1/blk00000001/blk0000001c/sig0000017b" is sourceless and has been removed.
The signal "cmulFP1/blk00000001/blk0000001c/sig0000017c" is sourceless and has been removed.
The signal "cmulFP1/blk00000001/blk0000001c/sig0000017d" is sourceless and has
... etc
see attachment
