What's the usage of the peelable mask on PCB?
LS-PCB
Newbie level 5
Newbie level 5
What's the difference between peelable mask and kapton tape?
Peelable mask is screen printed on the PCB during manufacture, so cab be more cost effective, as you don't have to cut tape, stick it down, and check it it.
    LS-PCB
Peelable mask is screen printed by the PCB fabricator, the cost of which can be less than that of an assembly worker adding Kapton tape just before flow soldering.
The use of it is to retain clean PTH holes when a board is sent through a solder bath so that the board can be turned over before components added and sent through the wave soldering machine again.
Some of the masks on the OP example PCB could be joined together so that peeling off is quicker.
It is also recommended to peel it off when the board is still warm, having just come off the solder bath.
LaTeX Commands Quick-Menu:
