Class-C amplifiers gradually entering class-B
neazoi
Advanced Member level 6
Greece
Hi, I have these two complementary amplifiers that operate on class-C.
I want to have a way to gradually convert both them into class-B, using a dual or preferably a single potentiometer (if possible) to do so.
By adjusting the potentiometer, I would gradually pass from class-C into class-B.
I guess some kind of biasing trick must be done.
Can you help me on this please?
You can introduce a potentiometer in the biasing network of each transistor to adjust the base bias voltage gradually. This will allow you to control the conduction angle from class-C towards class-B. To use a single potentiometer for controlling both transistors simultaneously, you can use a dual-ganged potentiometer.
    neazoi
Can you give me an example in My circuit, especially the pnp? It might sound trivial but I would like ti see it
LaTeX Commands Quick-Menu:
