what is incremental resistance in transistor?
khatus
Member level 3
Member level 3
Here what does it mean by incremental resistance?
In CB config input is a fwd biased junction, essentially looks like a diode :
Regards, Dana.
Incremental resistance is, as others pointed out, the slope at a particular point. The important thing to understand is that, since the slope of the curve changes depending on the point of the I vs V curve you are located, the resistance changes as well.
Take for instance an ideal resistor, if you change the signal voltage you apply to it the resistance doesn't change, but, with transistors or diodes, resistance is dependent on the signal voltage applied to them. So the main application of the theory behind all of this is that if the signal voltage variation is small enough, the resistance variation is also small and we can approximate it as a constant resistance. This is the so-called small signal model or small signal approximation.
One way to measure it is define the linear approximation of the bulk resistance above square law saturation for Rce. Which is actually the difference between Vbe and Vce over Ic.=Rce = Vce(sat)/Ic.
All diodes and LEDs have similar Rs*Pmax<=1 from Irated to 10%. Which is useful for interpolating using this average incremental bulk resistance above the knee.
LaTeX Commands Quick-Menu:
