Display enable vs Data Enable in LCD
FreshmanNewbie
Advanced Member level 1
In this datasheet: https://ww1.microchip.com/downloads...heets/SAMA5D2-Series-Datasheet-ds60001476.pdf
I'd like to understand the difference between the functions of pins mentioned below:
What is the difference between LCD Data enable vs LCD Display enable?
EN is used in the data interface ... as shown in the timing diagram
DISP is used enable/disable (energy saving) the display .. as the text says
I´m sure there are more detailed datasheets/documents.
Klaus
LaTeX Commands Quick-Menu:
