thannara123
Advanced Member level 5
Hi experts ,
see the image
0 to 260 volts AC at 50 Hz is supplied to a resistor network, as shown in the circuit above. The op-amp and series resistor are used to scale down the voltage for sensing by a microcontroller.. An offset dc voltage 1.65 volt is given to the inverting input to shift the ac wave as required .
In the above simulation the circuit and its output is worked as expect .
However, in the real world, my circuit does not perform as expected. The gain is not matching the calculated values; instead, it is higher. Changing the feedback resistor does not yield the expected effects according to the calculations. Look the video the signal is distroying when icreas the input ac volt
Any help is appreciated.
using op amp is LM358 ,
see the image
--- Updated ---
