Thermal resistance in LDO
engr_joni_ee
Advanced Member level 3
I have found in a LDO voltage regulator the following information.
Junction-to-ambient thermal resistance = 28 degC
Junction-to-case (top) thermal resistance = 43 degC
This look like strange to me. How the junction-to-ambient is lower then the junction-to-case (top) thermal resistance ?
The thermal vias, lowest Rth, on leadframe, closest to bottom of case....
Top of case is a sandwich, plastic covering die, so much higher Rth ?
Regards, Dana.
Is it not like that, junction to ambient thermal resistance is the sum of junction to case thermal resistance and case to ambient thermal resistances ?
If thermal resistance junction t ambient is smaller compared to thermal resistance junction to case then which way the heat is going faster to the ambient, side ways and not through the top case ?
LaTeX Commands Quick-Menu:
