[SOLVED] Slug tuning impedance matching
jadnounyah
Member level 1
Member level 1
I have a work I gotta do on finding the range of values on the Smith chart for matching a circuit using the slug tuning and honestly I don't even know where to start, I would like to use ADS for this. Info on such a tuning method is really scarce. Can anyone help me with a schematic setup or a reading resource for setup information?, I would be very happy. Thank you
Old-time multi-band radios were built on thru-hole circuit boards. The units contained several tuned slug inductors or tapped inductors. Some were wound on tubes, others installed in cubicle cans big as your thumbnail. I had one radio with instructions telling what section of a band to tune to, and which inductors or capacitors to adjust in sequence in order to get loudest reception.
It's important to use a non-metallic tool to turn the ferrite. Radio Shack carried a set of plastic hex wrenches and screwdrivers, since plastic did not alter frequencies when brought near the inductor. (I remember breaking a couple slugs by using a plain steel screwdriver.)
Link to discussion:
ham.stackexchange.com/questions/14505/is-it-practical-to-use-a-slug-tuned-variable-inductor-in-an-antenna-matcher-aka
    jadnounyah
