abbaszandilak
hi there. As you know TEMD5020x01 is a photodiod and when the sensor goes under an IR exposure it will make a response but it is so important for me to know the amount of the response to find out is possible to couple the sensor with Arduino or select another approach is the solution. thank you all. datasheet of TEMD5020X01:https://www.vishay.com/docs/84685/temd5020.pdf
