sabu31
Advanced Member level 1
Dear All,
I want to know what is general practice for the layout of the ground path, particularly in two-layer boards, and if you don't have space for the uncut ground plane.
Basically, I a have microcontroller which gives PWM and senses signals through ADC. The PWM signals are around 100-150kHz. Now the ground pin is common. and Vcc is 3.3V. So how to should the ground be routed so that cross-talk is avoided or distortion is prevented in the adc sense signal?
Should there be separate ground paths for PWM and ADC signals which are then joined at the GND point of the microcontroller or what is best practice? I am attaching a generic diagram for understanding.
