DDR Termination resistor placement clarification
newbie_hs
Full Member level 2
Full Member level 2
Dear Team,
why Termination resistors (tied to VTT) are located right next to last memory device.
You can have series terminations at the source. Or parallel termination at the end of the string. Or both. It depends on your requirements.
The question is too general, you need to refer at least to used memory technology (DDR, DDR2, DDR3, DDR4). They have different termination options and due to different speed, different requirements. Newer DDR families have mostly dynamic on-chip termination (ODT) and no termination resistors. Fixed resistor termination has been used with DDR and partly DDR2.
the end_of_line termination is most effective.
If the driver sends out a signal. It travels along to the end.
* without proper termination it becomes reflected and the reflection signal travels back to the driver. Causing refelction error all the line.
* with end_of_line termination .. there is no reflection. No erroneous echo signal travleing back.
Klaus
LaTeX Commands Quick-Menu:
