engr_joni_ee
Advanced Member level 3
Referring to section 3.2 High Speed Differential Signal Rules.
Point number 4: "When possible, route high-speed differential pair signals on the top or bottom layer of the PCB with an adjacent GND layer. TI does not recommend stripline routing of the high-speed differential signals."
Given microstrip is not symmetric compared to stripline having reference layers on top and bottom. If differential signals, there are two components, one is common signal or the common voltage level and the other is differential signal or the differential voltage level. I guess in the asymmetric geometry the speed of the common part and the differential part does not remain the same as in case of microstrip and that is the reason we do not route high speed signals on top and bottom layers. Because of symmetric geometry in case stripline, we route the high speed signals in inner layers.
But the TI document is describing something which is opposite.
Point number 5: "• Ensure that high-speed differential signals are routed ≥ 90 mils from the edge of the reference plane." I am not sure what does that means. Kindy explain this. Thanks in advance.
