Getting Parse Error while simulating Power Amplifier using ADS
pusparaga
Full Member level 4
Full Member level 4
I have created sub-circuits for input and output matching of Power Amplifier and also included Optimization. I am getting Parser Error as it is showing Parser Error at line 50. How to remove this Parser Error and how to find out line number in 50 in ADS.
Have you defined your variables for optimization?
Use in menu Simulate-> Generate Netlist for seeing your Netlist.
Regards
    pusparaga
Regards
Yes, I have generated Netlist. In the error message, it is showing error in the line number 15. I went and searched line number 15 parameters. Even I checked and changed MSTEP:Step2 N__6 N__10 Subst="MSub1" W1=0.835 mm W2=1.5 mm. But I couldn't able to remove error. I have attached netlist report, error message, schematic, symbol generated for input and output matching, input matching, and output matching.
  • Netlist.pdf
Correct "Hu" value in MSUB definition.
As you mentioned, I corrected Hu and simulated. But I am not getting problem from Hu. Later I am getting example MLIN2 TL12. Once again I corrected problem of MLIN2 TL12. Next time I am not getting problem from TL12, but am getting TL11. Once I corrected TL11, next time I am getting problem from TL10. It keeps on going for TL10, TL9, TL8, TL7............
I am really confused. Just I have followed Anuragh Bhargav's Page No. 14, 18, and 20 YouTube RF -Power Amplifier Design Tutorial-17 (Attached Below). Is there any problem in input matching or output matching or main schematic. I am not really understanding. Guide me how to simulate this without any error.
  • Anurgha_Bhargav_RF_Design_17_Tutorial.pdf
As you mentioned, I corrected Hu and simulated. But I am not getting problem from Hu. Later I am getting problem example MLIN2 TL12. Once again I corrected problem of MLIN2 TL12. Next time I am not getting same problem from TL12, but am getting TL11. Once I corrected TL11, next time I am getting problem from TL10. It keeps on going for TL10, TL9, TL8, TL7............
Your netlist PDF has some extra line breaks that confuse when searching for the "true" netlist line 45 that causes the error.
How to avoid some extra line breaks that cause error. When we go and search line 45 or 50. There are no errors at all.
How to overcome this parse error.
I have simulated once again and attached below the error messages and netlist pdf also.
  • Netlist_PDF.pdf
You totally misunderstand things!
The error is not from the line break. The line break that I mentioned is only relevant in finding the error line in your netlist. Your editor breaks long lines, so that the line number seen in your editor is not the true line where ADS reports the error.
You can choose a smaller text font in your editor, to avoid the line break. Then you will hopefully see in editor line 50 the content from ADS netlist line 50.
    narayani
Parse Error is showing in line number 50. But when I went and checked showing error in the line number 50. But it seems to be ok. I couldn't find error in MTEE7.
--- Updated ---
--- Updated ---
--- Updated ---
--- Updated ---
--- Updated ---
OMG, why is it so difficult to save the netlist into a simple text file and open it in the editor (or post the netlist here)? With your RTF you have messed up the contents again, with all these \par that are not included in the original netlist.
I spotted one mistake in your netlist screenshot, but that's not line 50 in your editor:
Problem is solved.
