can i use a variable flag as trigger like high priority Interrupt
thannara123
Advanced Member level 5
Its hard to understand what i am asking please am sorry ,
Can I use a variable like interrupt trigger with high priority ?
Or Interrupt funtion is only applicatple for peripherals and external interrupt ?
An interrupt usually is hardware based
A variable usually is software based.
So: NO, I don´t think it´s possible.
I even don´t think it´s useful. Because if you want to software trigger for an ISR to be xecuted, then why not simply call a function instead.?
Klaus
    thannara123
Typically you can use a GPIO pin as a flag, and use its interrupt capability
to do an interrupt when you write to the GPIO. Thats more of a standard
HW approach.
Or use Verilog solution to manage monitoring of a bit in a variable and
trigger an interrupt. ARM and appropriate IDE can handle that, like a
PSOC. The compiler/linker has to know the address of the variable, thats
easily handled.
In PSOC could use a control reg (it can be 8 bit) as a variable and do this :
The compare is multi compare selectable>,<, <=......
Could even add HW between Control reg and ISR to logically qualify it.
Could replace digital comp with a LUT and implemented it as a state machine or
a simple PLA to qualify ISR from the variable.
Regards, Dana.
Since by definition both ISR and Main() are functions asynchronous to each other, it is necessary that the value of the variables manipulated by the interrupt service have a specific entry point into the main program.
In other words, the ISR update specific temporary global variable(s), and the Main() read them at a specific interval/function.
To trigger an exception procedure, ARM processor, e.g. STM32 has a special SWI (software interrupt) instruction. I don't see a purpose of using a flag instead.
