FlyingDutch
Advanced Member level 1
- Joined
- Dec 16, 2017
- Messages
- 458
- Helped
- 45
- Reputation
- 92
- Reaction score
- 55
- Trophy points
- 28
- Location
- Bydgoszcz - Poland
- Activity points
- 5,029
Hello, forum
I write a VHDL project in which I instantiate components by using the "for .. generate" loop. These components work fine (in real hardware), but I have also need to refer to them in process in top entity. I have an error when referring to generated components in process in the top entity of the project.
Here is code of my top entity:
The instantiated components ports are
The "for .. generate" loop code is:
When I am trying to refer to one of the generated components using:
I have an error:
[Synth 8-995] my_gen is illegal in an expression ["/home/bofh/_FPGA_TSN_Proj/Xilinx/TSN_FPGA_22CH_Spartan7/src/top_TSN.vhdl":191]
Could somebody give me a clue why this error is generated?
Thanks and Regards
I forget to tell you: I am using Xilinx Vivado v2019.1 (64-bit) on Linux Mint. What is interesting - I can see components instantiated by "for .. generate" loop in synthesised project (on Schematics) - see screen:
The components has names: MY_GEN[index].channel
Thanks in advance
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
library work;
use work.all;
--use work.LAT_Channel;
entity top_TSN is
generic (
NCH : natural := 22 --Liczba kanalow 20
port (clk_t : in std_logic;
rst_t : in std_logic;
CH_ON_t : in std_logic_vector(NCH -1 downto 0);
CL_t : in std_logic_vector(NCH -1 downto 0);
KSM_t : in std_logic; -- kasowanie alarmow jeden sygnal
GSM_t : out std_logic; -- generator sygbalu migowego: jeden sygnal
HL_t : buffer std_logic_vector(NCH -1 downto 0);
HAL_t : out std_logic_vector(NCH -1 downto 0);
ALARM_GLOB : buffer std_logic; -- Alarm globalny logic: 3,3 V
BUCZEK : out std_logic; -- Alarm globalny logic: 12 V
TEST_LED_t : std_logic; -- test LED (active Low)
uart_tx : out std_logic; -- UART Tx output - do rejestratora staku
btn1 : in std_logic -- tylko do testow
end top_TSN;
architecture Behavioral of top_TSN is
component LAT_Channel
port (clk : in std_logic;
reset : in std_logic;
CH_ON : in std_logic;
CL : in std_logic;
KSM : in std_logic;
GSM : in std_logic;
HL : out std_logic;
HAL : out std_logic;
TEST_LED : in std_logic;
ALARM_CH : buffer STD_LOGIC;
ALARM_CH_DEL : buffer STD_LOGIC
end component;
component GSM
generic (
NBit : natural := 32;
Div : natural := 13000000
Port ( clk : in STD_LOGIC;
clk_out : inout STD_LOGIC);
end component;
component uart
generic (
DELAY_FRAMES : natural := 208;
NCH : natural := 20
uart_tx : out STD_LOGIC;
btn1 : in STD_LOGIC;
lanterns : in std_logic_vector(19 downto 0);
alarms : in std_logic_vector(19 downto 0)
end component;
constant TRIGGER_TIME : integer := 24000000;
signal sw_mig : std_logic;
signal alarm_glob_sig : std_logic := '0';
signal j : integer;
signal triggerUART : std_logic := '1'; -- active Low
signal clockCounter : unsigned(28-1 downto 0):= (others => '0');
signal bylo_kasowanie_alarmu : std_logic := '0';
signal new_alarms : std_logic := '0';
signal blokada1 : std_logic := '0';
signal alarms_LAT: std_logic_vector(NCH -1 downto 0):= (others => '0');
signal alarms_LAT_DEL: std_logic_vector(NCH -1 downto 0):= (others => '0');
begin
Port_UART : uart
generic map(
DELAY_FRAMES => 208,
NCH => 20
port map ( clk => clk_t,
uart_tx => uart_tx,
btn1 => triggerUART,
lanterns => CH_ON_t(19 downto 0),
alarms => HL_t(19 downto 0)
gen_SM : GSM
generic map(
NBit => 32,
Div => 13000000
port map (clk => clk_t,
clk_out => sw_mig
MY_GEN : for i in 0 to NCH - 1 generate
channel: entity work.LAT_Channel(Behavioral)
port map (
clk => clk_t,
reset => rst_t,
CH_ON => not CH_ON_t(i), --Active 1
CL => not CL_t(i), --Active 0
KSM => not KSM_t, -- kasowanie alarmow wspolne (Active 1)
GSM => sw_mig, -- GSM wspolnywas_alarm := '1';
HL => HL_t(i),
HAL => HAL_t(i),
TEST_LED => not TEST_LED_t, -- test LED wspolny (Active 0)
ALARM_CH => alarms_LAT(i),
ALARM_CH_DEL => alarms_LAT_DEL(i)
end generate;
BUCZEK <= (ALARM_GLOB and (not(bylo_kasowanie_alarmu))) or (new_alarms);
-- proces: wypracowanie alarmu globalnego
sum_alarms : process (clk_t, CL_t)
variable alarm_g : std_logic;
begin
alarm_g := '0';
l_sum : for k in 0 to NCH - 1 loop
if CH_ON_t(k) = '0' then
alarm_g := alarm_g or (CL_t(k));
end if;
end loop l_sum;
if TEST_LED_t = '1' then
ALARM_GLOB <= '1';
else
ALARM_GLOB <= alarm_g;
end if;
end process sum_alarms;
kas_alarm: process (KSM_t)
begin
if KSM_t = '0' then
bylo_kasowanie_alarmu <= '1';
-- l_01 : for k in 0 to NCH - 1 loop
-- if CH_ON_t(k) = '0' then
-- old_alarms(k) <= CL_t(k);
-- end if;
-- end loop l_01;
end if;
end process kas_alarm;
rerun_alarms : process (CL_t(0),CL_t(1),CL_t(2),CL_t(3),CL_t(4),CL_t(5),CL_t(6),CL_t(7),CL_t(8),
CL_t(9),CL_t(10),CL_t(11),CL_t(12),CL_t(13),CL_t(14),CL_t(15),CL_t(16),
CL_t(17),CL_t(18),CL_t(19))
variable was_alarm : std_logic := '0';
begin
was_alarm := '0';
was_alarm := MY_GEN(0).channel.ALARM_CH;
end if;
end loop l_01;
new_alarms <= was_alarm;
end process rerun_alarms;
-- proces: trigger do wyslania danych przez UART do rejestratora statku
trig_uart : process (clk_t)
begin
if rising_edge(clk_t) then
clockCounter <= clockCounter + 1;
if (clockCounter > TRIGGER_TIME) and (clockCounter < TRIGGER_TIME+20) then
triggerUART <= '0';
else
triggerUART <= '0';
end if;
if clockCounter > TRIGGER_TIME+20 then
clockCounter <= (others => '0');
end if;
end if;
end process trig_uart;
end Behavioral;
entity LAT_Channel is
reset : in STD_LOGIC;
CH_ON : in STD_LOGIC;
CL : in STD_LOGIC;
KSM : in STD_LOGIC;
GSM : in STD_LOGIC;
HL : out STD_LOGIC;
HAL : out STD_LOGIC;
TEST_LED : in STD_LOGIC;
end LAT_Channel;
port map (
clk => clk_t,
reset => rst_t,
HL => HL_t(i),
HAL => HAL_t(i),
ALARM_CH_DEL => alarms_LAT_DEL(I)
end generate;
Thanks and Regards
--- Updated ---
Thanks in advance
