Calculate ESR of Electrolytic capacitor over frequency sweep?
In theory ESR doesn't vary with frequency. It is a DC resistance in series with the ideal capacitance. So, you must calculate the ESR at 120Hz which is how the D.F. is specified. Xc will vary with frequency, but the ESR is still "ideally" the same - 159mR.
Z in ohms = 0.048 according to data sheet, 20 deg C 100kHz
for various electro-chemical reasons the resistance is higher at 100/120 Hz
--- Updated ---
Also tan-delta, or DF, is multiplied by the VA the cap sees to get loss in watts
from this if you know the rms current - you can get an effective ESR for that freq, some of that loss is parallel current loss in the dielectric ... so not strictly ESR
If you were to measure the ESR of an electrolytic capacitor you will find that it stays mostly constant up to around 150KHz and then the ESR starts to go down until around 2MHz where it then goes crazy due to inductance effects.
If you were to measure the ESR of an electrolytic capacitor you will find that it stays mostly constant up to around 150KHz.
Thanks, though the DF calculation does indeed give ESR = 0.159R at 120Hz. Though the datasheet gives ESR at 100kHz as 48mR....so there is some unknown function of ESR and frequency.
See this TDK curves:
Thanks, ayk, tan delta = ESR/Xc....So if tan Delta increases with frequency, then so must ESR....but this is not the generally accepted case..
The values of DF and 100kHz impedance are maximums. Typical values would be much less than those.
I don't have the exact same capacitor you are using, but I have something close. Using a Rubycon 1000 uF, 35V, VX series capacitor, here is a sweep of its DF and ESR versus frequency. The analyzer doesn't show DF greater than 10. These curves are very typical for aluminum electrolytics:
coft-png.183869
Notice that the value of DF at 120 Hz is about .04, and ESR at 100 kHz is about .030 ohms.
