Via size and spacing
rd_dinesh
Member level 1
Member level 1
I'm designing a power amplifier on an RT6006 board,
I want to place vias in my design, I want to know how we can decide the size and spacing between the vias.
for grounding the capacitors(i.e, routing between the layers)
What current? What frequency? There are lots of free tools out there to help you calculate appropriate size. You've given us no inormation. Just search
"Via suze calculator"
    rd_dinesh
currents through various capacitors in two different modes of operation.
Keep in mind every trace and via adds about 1 Ohm/mm per GHz based on ESL of 0.6 nH/mm for path length.
So be aware why your Vdd noise spikes dV=Ic*dt/C and how damping works in simulations from impulse transitions. ( drivers )
If you do not know how to simulate it. Find out.
