Shuo__
Newbie level 6
Hello everyone, after reading a lot of information on the internet, I am now confused and need your help.
The question is how should I choose the core material for high frequency current sensor (1MHz-20MHz). I have gathered two views here :
I would be very grateful for your advice!
- Selection of materials with high magnetic permeability. Materials with high permeability are selected, and their higher permeability usually means that it has less impedance to high frequency signals. This is because the permeability of a core material is the ratio between the magnetic flux density and the magnetic field strength, indicating the responsiveness of the magnetic field in the material. In high frequency applications, the greater the permeability of a core material, the faster the material can respond to changing magnetic fields, and therefore the lower the impedance to high frequency signals.
- Selection of materials with low magnetic permeability. "With most ferrites, the permeability doesn't just drop at high frequency, the material also becomes absorbent; At "low" frequency you will have real permeability - the coil will work like an inductor, store and release the magnetic field; but at high frequency, you get imaginary permeability, the coil will work like a resistor - the magnetic field will be turned to heat; this is the principle on which ferrite beads work."--From FesZ. According to my understanding, in order to minimize high frequency losses, low imaginary permeability materials should be used. and the materials with low permeability have smaller imaginary permeability at high frequencies than materials with high permeability.
