cupoftea
Advanced Member level 6
I was testing a "bidirectional forward converter" 240VAC with high voltage capacitor reset.
I broke the path in the HV cap to solder in a sense transformer.
But then took it out, and powered up, forgetting that the HV reset cap was now open circuit.
Due to this, the transformers leakage and magnetising inductance energy then had nowhere to go....and so blew up the low side NV6128 GaNFET
NV6128
The thing is, the high voltage got connected, via the blown FET, directly to the control circuitry, and blew a good few things up there aswell.
Would you say these kind of GaNFET modules are more likely to blow up and cause control circuit damage, when compared to just plain old TO220 Si FETs?
NV6128
