How to remove parse error in ADS2022
hari_preetha
Full Member level 2
Full Member level 2
I am getting parse for my designed circuit. It is telling there is unexpected number in line7. How to find line numbers and how to eliminate parse error.
Check the file called "netlist.log" in your workspace directory. This is a text file so it should be easy to identify line #7.
Using the command "Simulate > Generate Netlist" in this schematic should open the default text editor window with this file to read.
I have downloaded both netlist and log file and attached. I am confused with these file. I am not understanding how to remove error in the line 7. Please guide me, how to fix this error.
--- Updated ---
Even I removed it every thing. I created new file, now also it is showing netlist error. Please guide how to remove this error.
  • logFile.txt
You cannot edit the netlist file, but you can use it to identify the problem that is causing the issue and edit the schematic appropriately and then ADS generates a new (hopefully correct) netlist file when you re-simulate the design.
Main problem is that you did not attach the netlist.log file as requested. Follow the details in my previous post to get the correct data. The simulation log report is not the requested information.
