Pic Kit 2 program problem
thannara123
Advanced Member level 5
Hello experts , I have an old pickit2 programmer ,I am trying to burn a hex code to the Pic16f877a.
The whenever I load the hexa code by clicking write button ,the Pickit2 shows successfully burned ..
If I read it again it shows the hex ,.
But the problem is whenever I reconnect USB of the Pickit 2,
And reads the hex code which is empty.
Why the Pic16f877A is not burn properly .
Is it Pickit2 problem .
Check the program memory protection bit.
CPD: Data Code Protection bit(2)
1 = Data memory code protection is disabled
0 = Data memory code protection is enabled
Check the meaning of this bit from an upcoming datasheet.
    thannara123
