Doubt regarding over-current latch
sabu31
Advanced Member level 1
Dear All,
I am trying to simulate the overcurrent latch circuit (Application 5) given the datasheet of ACS712.
However, when I am simulating the system in LTSPICE, I am not getting the desired result. I am not able to understand the function of the Diode and Resistance R1. When I remove the diode, the circuit functions as required. What could be the issue?
  • Current_Fault_Latch.pdf
Unfortunately you didn't give the resistors the same names as in the datasheet. This can cause confusion.
Did you also use LMV7235?
Why didn´t you use the same resistor values as in the datasheet? 100k/100k makes no sense at all, because it means "trip at zero current". It´s like buying a fuse for 0mA.
(why using different values but complaining about different behaviour?)
This is no error description.
What is your "desired result" and what do you see instead?
I doubt this. (For me: this makes no sense)
Please tell us what your required function is.
R1 (P_PU in datasheet) is the pull up resistor required for usual comparator outputs (open collector).
D1 is the "latching function".... as described in the datasheet: "This circuit latches an overcurrent fault and holds it until the 5 V rail is powered down."
Klaus
I am sorry, I used MCP6021. However, even if I remove the diode it still works as a latch. Also I needed to disconnect the resistor connecting output to 5V rail.
The issue is due to LM7321 being an open collector?
I really feel sorry that both share the same schematic symbol.
There are OPAMPs and comparators, and there is a good reason why they have different names.
They have different names, because they have different functions /operation modes.
OPAMP: (incomplete list)
* very low differential input voltage (say "zero"). Often needs some time to come out of saturation.
* output is analog, usualy never hitting the rail.
Comparator: (incomplete list)
* may have high differential input. Doesn´t suffer from saturation.
* output is digital, usually saturating hitting the one or the other rail (lower rail only, in case of OC output)
You may "mistreat" an OPAMP as comparator ... but often causes problems.
Sometimes you may "mistreat" a comparator as OPAMP ... but usually causes problems.
But I don´t understand "why" one would do so.
I would never come to the idea to use a round manhole cover as bicycle wheel .... just because it is round ;-)
BTW: you could do your own research on "difference between OPAMP and comparator", it gives me more than 1.5 million hits.
Klaus
    sabu31
As you can see the diode changes the trip levels depending on what state
output is in. In effect it is a form of hysteresis. Hysteresis is symmetrical
about a trip point, this is asymmetrical due to diode.
Note it also is input amplitude sensitive, if I change the sine from 10V to 8V
pk-pk it wont switch, with output staying low. In effect it functions as a discriminator
of sorts.
My sim show's R1 does not effect anything, although I would think one
might observe a little higher 1 level out of OpAmp.
Regards, Dana.
