neazoi
Advanced Member level 6
In this voice processor
I would like to know which resistors (anodes/cathodes/grids?) need to be of higher wattage than the standard 250mW through hole ones we use today.
If voltage is the problem, can I use two 250mW modern ones of half resistance value in series for each of them?
The whole circuit requires 5mA at 300Vdc from the power supply.
Thanks
Thanks
