[SOLVED] Understaning the code of following
thannara123
Advanced Member level 5
I am learning the sinewave generation a great member Thahamid posted a blog in edabord as follwos
i didnt understand the working of following code anybody help me ?
TBL_POINTER_SHIFT = TBL_POINTER_NEW >> 11;
DUTY_CYCLE = TBL_POINTER_SHIFT;
what are the values of TBL_POINTER_SHIFT variable
it gets 1 when the TBL_POINTER_SHIFT become 2048 ,with lower the value it will be zero
am curiuos how the technique behind it ?
The variable names are somehow contra-intuitive.
It's basically a DDS generator. What they call TABLE_POINTER_xx is usually designated DDS accumulator. The upper 5 bits are used as index into the sine table.
    thannara123
