Input voltage to 110VAC inverter?
cupoftea
Advanced Member level 6
We are doing a pure sine 110vac inverter.
Its +/-15% so vac can be up to 126VAC.
So max peak is 179V
As such, woudl you agree, we need our VDC input to be 200V?
so many questions, so little information
if the source can support it, why not boost whatever the input voltage is to
180V plus whatever overhead one needs to get the desired output?
what's the input voltage?
what's the required output power? available input power? etc etc etc
So max peak is 179V
No, I would not agree.
(Transformers, you know.)
Thanks, i mean the input to the actual inverter itself. The atual input is 18V. We will isolate this, then boost it up to 200v.
I guess it has to be 179V min....just if we pick 179v...then our sinusoidal PWM has to be able to go to 100%.
