Some questions about bicircular polarized antennas
antenna1895
Newbie level 5
Newbie level 5
Dear master, today I simulate an antenna.My results are very different from the ideal results, when I want to increase the operating frequency (change the original structural parameters), the left-handed and right-handed circular polarization plots have changed dramatically, can you provide some ideas to solve this problem?(The left picture is my result ,the middle is the ideal result and the right is my model)
The picture on the left is the edit sourses and the right one are the ports.(I use wave ports).Thanks for your reply.
Although it's difficult to tell which objects are your wave ports, I would guess that likely either the individual elements you have there are enforcing too linear a polarization, or your simulation is not adequately meshed.
I would lean towards the latter -- could you post your convergance settings and meshing/convergance results?
Thanks for your reply, I set ten as the maximum number of iterations.But in fact,there are only four. Maybe that's the problem?And could you give me some advice?
That doesn't look too bad, but it's hard to tell. Under "Options" set minimum converged passes to 5, and see if anything changes. It will take a while to run, but if the results change then there is a problem with the convergence. If you get the same results, then it might be something else in your setup.
It is difficult to interpret a plot with no legend and no labels.
I will improve , thanks
I will try ,thank you very much
Here is my project.
--- Updated ---
I am sorry to trouble you again, I set minimum converged passes to 5,but everything is the same. I try to improve the frequency but I fail to meet the requests for dual circular polarization.(In the paper which I try to simulate,the frequency is on the UHF.)
  • Project1.zip
I am curious how you can really build this antenna, do you have prototype photo to show, or any resource paper?
Actually I know the answer for you.
Best,
Tony Liu
o
of course, thank you very much. I have successfully reproduced this model, and I try to improve the frequency for miniaturization. Now, I try to change the reflectively for suppress the antenna posterior lobe.
--- Updated ---
o
But can IEEE papers be uploaded like this?
  • Compact_Low-profile_Low-mass_UHF_Folded_Shorted_Dipole_Antenna_Array_with_Dual_Circular_Polari...pdf
I used your HFSS file, and got the result as the attachment, is that similiar to the ideal?
Hope that can help you.
