cupoftea
Advanced Member level 6
For the above spec, i woudl think Planar would be a good option.
Planar is one of the only high-(ish) power SMPS that suffers from high levels of leakage L in the transformer......Both primary FETs get overvoltaged and secondary diodes.....so i would think planar (with its very low leakage L) , is a good option for pushpull?
However, when 2 sync rects are used with a pushpull with dual sec windings...then even if leakage L is vanishingly low, you can still get high overvoltages on the sync rects when they happen to turn off when current is flowing through them drain->source (back-flow current).........so maybe planars arent so good for pushpull after all....because the worst overvoltage on the sync rects, comes from the fet suddenly blocking back-flowing output indutor current.
Though is the push-pull the only hard switched , high-ish power converter that can really benefit from planar?
