knicklicht
Junior Member level 1
Hello all,
I am trying to build a very cheap circuit that contains a DAC as well as a Class-D amplifier. As an input I have a Zedboard FPGA. I want to generate a 1.8 V PWM signal and bypass the analog input stage typically found in the circuits that I found. The output load is a 4 ohm speaker and I am looking for around 50 W of RMS power output. I think my lab power supply will be sufficient at first. Most amplifier circuits that I saw use around +/-15 V. However, it only supplies positive voltage. That's why I chose to build a differential amplifier. Since I have a digital circuit background I am unsure about the components that I need. I found a design that uses very few components. It basically consists of an analog input stage that generates the PWM signal (which I don't need). The PWM signal is passed to an SN74LVC2G86 XOR gate to generate the differential signal. Then it uses two MP8040DN high current integrated half bridge + drivers. I was able to source the XOR gate but the MP8040 is not readily available in Europe (only on AliExpress). Is this IC the right choice here or are there alternatives that are more popular? I do not need a drop in replacement as long as I have a cheap design that fulfills my requirements. I am also trying to keep the output low pass filter as simple and cheap as possible. I was thinking of 25V 1mF electrolytic capacitors and 15uH SMD CD75 power inductors. Will this work?
Thanks
Thanks
