vinodquilon
Full Member level 3
I have designed oneshot for 1ms Pulse width using 4047.
R5- makes output current >= 10mA to ensure load regulation.
C4- prevents bouncing of trigger switch.
1N4002- prevents discharging of c1 through LM317T.
1. Is it possible to see the 1ms 'short time' switching between RED & GREEN LEDs at output of 4047 ?
2. Can I use C4 in parallel with C1 as both have different roles in the circuit ?
3. 10K or 100K which one is better to pull down trigger switch to GND ?
