d123
Advanced Member level 5
Too much time in DC and not enough in AC...
This transformer:
1) Is there any need to put a fuse at the input to the primary as it says it is 'short-circuit proof'? Even if not necessary due to transformer design, is it still a good idea to put a fuse at the primary input side anyway in a circuit such as the following (it's only a rough/preliminary sketch)? A MOV, maybe, but the fuse? And if needed do I size it, as I saw somewhere else online, it would be 2.3 VA/230 VAC = 10 mA? - I find that hard to believe and almost ridiculous, I don't remember having seen a 10mA AC fuse in my life, more usually 3A, 10A, 13A, etc.
2b) Why is it 1.6 and not 1.414? What does 'app. x factor' mean in English/Human Being language?
2c) 'No-load loss (typ.)' of 1.2W with reference to which side of the transformer? Primary, I'm guessing: if I have no load whatsoever on the secondary, the wasted power at the input/primary side is 1.2W?
2a) and 2d) I'm a bit lost as to what current I can hope to draw from each secondary output between VA, W and trafo efficiency. I've had this conversation before with a member but it was a few years ago and do not remember their exact answer.
Going on the datasheet specifications and the 'Efficiency' section in this tutorial called Transformer Basics and Transformer Principles, below comes yet another image, this one is of the tutorial's formulas:
When I calculate 2.3 VA x 0.52 efficiency = 1.196 W. So, wearing my angry dunce's cap, I really must ask, is that what REAL POWER I can expect at the combined dual secondary side? Is that AC, DC, what exactly - do I then need to do 1.196 W x 0.707 = ~0.845572 W in DC as a rough idea or not at all?
If I do the simple - and I think incorrect - 2.3VA/15V = 153mA. If I then do the equally incorrect and misguided 153mA x 0.52 efficiency = ~80mA. So, then each secondary cannot output 15V and 76mA, but only 15V and 40mA?
Or, as in a thread I just read here, from what I understood, I need to assume that output power is 1.2W, and the 52% efficiency refers to 2.3 VA x 1.52 = 3.496 VA used at the primary side to produce the 2.3 VA at the secondary side. So, my above calculations are even more meaningless, and useless - correct?
Finding something so seemingly simple a bit hateful to grasp what I want to know, so thanks. My main question in this lengthy essay of hopelessness is how much AC average current can I actually hope to get out of the secondaries?
___________________________________________________________________
Different question(s):
Looking at the schematic, thinking of a very simple dual power supply just to test little things and no great voltage regulation precision required, and then considering the option of separating the secondaries and using two bridge rectifiers (one forward biased for positive supply, the other reversed for the negative supply, etc.) what configuration is less problematic with regard to varying loads and unbalanced loads between V+ and V- outputs? Does the transformer care how much power each secondary individually uses? This may seem a (very) stupid question but I'm curious, if I draw the whole secondary side 80mA from the positive output only, then surely the negative output will droop to death or fight the positive to get its share of the current? What do dual secondary transformers do in that respect?
What are D5 and D6 for, by the way? I basically copied the schematic from a very old ST power supplies app note.
Thanks.
This transformer:
Thanks.
