Junus2012
Advanced Member level 5
Hello,
I have a digital signal from a control unit with Logic '1'=4.95 V and logic '0'=1.65 V,
I want to convert it to logic '1'= 3.3 V and logic '0'= 0 V.
My idea to translate this voltage is by connecting a comparator with a supply voltage of 3.3 V, I tie the inverting input to a low voltage like 0.5 V (or any safe low voltage that fall with the input range of the comparator).
The critical case in this idea is when the input voltage is at 4.95 V, which is 1.65 V above the supply voltage of the comparator which is not accepted by many of the comparators I searched. However, I found the LM393LV-Q1 Dual and LM339LV-Q1 from Texas Instruments can handle it
The other problem is when I want to feedback my control unit, in this case, I need to convert the 0, 3.3V to 1.65, 4.95V
The speed is another problem, the LM393LV is limited to maximum toggle frequency of 1 MHz, while I need above 10 MHz.
I searched in logic level translator circuits, but I found those IC works perfectly with respect to ground (0 V), while you see I have 1.65 V in either of the sides.
Thank you for your help in advance
Regards
Regards
