The schematic is a part of a signal conditioning circuit. The input to this op amp would be from a hydrophone.Hi,
@OP:
Where is this schematic from?
Doesn´t it come with some infromation?
Klaus
1. R2 and R3 seem like a voltage divider. What is their purpose here?Have you any open questions beyond the points that have been already answered?
How did you find this? Where should I look for this information in the data sheet?By the way, according to datasheet AD711 won't work with 5V single supply. Minimal supply voltage +/- 4.5V, negative Vcm limit Vs+4V.
It seems you are not that experienced in reading datasheets, thus I tell how I do it:How did you find this? Where should I look for this information in the data sheet?
I didn't quite understand this. Can you explain a bit more on this? What would happen if the non inverting terminal is tied to ground?2. Typical bias circuit for single supply OP.
