inability to place pin and label in layout - cadence virtuoso
mohamis288
Full Member level 3
Full Member level 3
Hello,
Whatever I try to define pin name in cadence, nothing will appear in the layout. I do not know why. Also, label section won't appear whatever I click on it.
Can anyone help me?
Which pins? There are too many and I only trust the ones out of
the "create pin" menus. Some instantiated out of libraries seem
to be not-what-I-wanted.
Pin texts (on a good pin to use) are "reflection texts" down in
the pin/symbol instance, which you access by property-editing.
It would be peculiar that no fill-form asked you about that (a
clue that maybe you're using the wrong source of so-called "pins").
In layout window press E. then tik mark the pin names options.
I think the labels are there, just their visibility is turned off in the display option.
Let me know if it helped.
    mohamis288
The pin is shown with it's name, but I can not place label yet.
