henry kissinger
Member level 2
I am trying to make a switch with NMOS, my goal is to achieve very low ON resistance.
I want the On resistance as small as possible. Using the NMOS model I am using, I found that with width as 180cm and length as 1nm gives me 1.86*10^-6 Ohm
but this is obviously impractical as the width is not possible to be 180cm and length not possible to be 1nm. How should I do it in way that is more reasonable?
