hafrse
Full Member level 3
Hello,
I have a Reel-2-Reel tepe recorder using the 4043 (U4) to latch the 3 control momentory buttons Play, Fast Forward and Fast Rewind The problem is only when selecting fast forward spooling only 10.5" and when it is accelerating , when using 5" all ok
Problem description:
Pressing fast forward, Latch output O0 pin 2 of U4 goes high (latches) for some sec. and goes low . It is different each time, sometimes it works for about 5 sec, sometimes 30 sec.... s , it seems that something with high load spooling giving som kind of disturbance (hard to locate).
the 4043(U4) is very sensitive, if I add a decopling capacitor to the +5 supply/gnd on pin7 and 14, it stops to latch! .... if I try to mesure with a probe on the outputs (O2,O0,O3) some times it does not latch on any buttun while I am mesuring.
I checked the supply rail +5 , all ok.
R0,R2,R3 inputs are all low when the latch releases after some sec on fast spool! . R0 R2 R3 goes only high momentary when pressing Stop (normal to release the current command)
Is there a miss in the design or can I add aditional filtering? u3 is a 8 bit priority encoder that encodes the 3 inputs from the U4.
Thanks for any help!
