Junus2012
Advanced Member level 5
Hello,
A common issue of the three op-amp instrumentation amplifier (in-amp) is the relationship between the required gain the common mode voltage of the input signal.
However, if we capacitively couple the input signal or even transformer coupling with a common mode voltage fixed to the middle of the in-amp then we must suffer from this issue. A circuit to perform this one is given below
The -3dB frequency of the coupling circuit is set by 1/(2*pi*R1*C1) and can be down do few Hertz.
My question is, if this solution is simple, why designers complain on the input common-mode voltage issue, basically when the DC is blocked at the input (decoupled), the amplifier behave just like an ideal rail to rail input stage.
Thank you
Best Regards
Thank you
Best Regards
