Techman_7
Full Member level 2
I am working on onboard charger project for electric vehicle of 11kW rating.
In that I considered UCC21750-Q1 SiC MOSFET driver. (Datasheet attached)
I have query that which MOSFET driving method is suitable bootstrap or zener diode method (negative bias supply)?
What are the pro & cons of bootstrap method over negative bias zener diode method for driving SiC MOSFETs?
Can negative bias be generated by bootstrap method for SiC MOSFETs?
For PFC -
Input = 415 VAC, Freq = 50 Hz
Output = 650 to 800 VDC @ 11kW
For High voltage DC converter -
Input = 650 to 800 VDC
Output = 200 to 450 VDC @ 10kW
For Low voltage DC converter -
Input = 200 to 450 VDC
Output = 9 to 16 VDC @ 3kW
Regards,
Abhishek
For PFC -
Regards,
Abhishek
