Op-amp simulation
FreshmanNewbie
Advanced Member level 1
I am not sure what's the mistake I am making on the below simulation.
Below is a Non-inverting op-amp (IC Link) with Gain as 3.
Case1 : Input: 1MHz; Offset:0.5V; Pk-pk Amplitude: 0.2V
enter image description here
Result:
The output gain is close to 3. And the input and output frequencies are same.
But if I increase the input frequency alone to 5MHz,
Below is the result:
Why is there a 60mV additional increase in the output voltage? Shouldn't it be the same 600mV?
I am trying to test the GBWP and slew rate with this op-amp.
Maybe spice model is not 100% accurate ?
And you have not included parasitics in your schematic.
I would have guessed gain peaking but your Cload = 0 so thats out.
Regards, Dana.
Dear FreshmanNewbie,
Even if the external load capacitance is not included in your test bench for the MCP660 op-amp, I examined its model and found it does include a 2 pf capacitance at its load. Hence, I suspect the reason you are observing a 60 mV increase in output amplitude with a 5 MHz input relative to the input amplitude and do not observe the 60 mV increase in amplitude relative to the input amplitude at 1 MHz is the transfer characteristic of the op-amp and its peripheral circuitry in your test bench.
Two options to attempt to confirm this hypothesis are:
1. Perform a small-signal AC analysis of your circuit with the input set to 1 V AC and observe the output voltage over frequency. This will illustrate the transfer function over frequency.
2. Apply a series of input frequencies and measure the gain at each frequency in a series of transient simulations to assemble the gain characteristic as a function of input frequency.
I hope this helps FreshmanNewbie!
Shawn
