very rare datasheet - SCR ( A69157)
PA3041
Junior Member level 1
Hi team Have a nice day
It would be grate help
I searched on google about this SCR ( A69157) for datasheet but I could not find the datasheet
It would be a grate help if anyone can help to have the datasheet for this SCR
Please see the attached image for device
Thanks in advanced
Teccor brand and Littlefuse has acquired some time ago.
You can request from Littlefuse, they will help you.
you can tell by the wider outer Cu pins and narrow middle one - it is a special - most likely automotive - information on what it was chopped out of would be helpful
have you tested it ?
Standard Teccor SCR had part numbers Sxxxx which are continued at Littelfuse. A69157 looks more like an OEM product for a specific customer, you won't necessarily find a datasheet. Do you expect specific device properties (e.g. GTO feature) or is it just a regular SCR application? In the latter case, what do you really want? Searching a replacement? Identifying a device in your spare box just out of curiosity?
Reactions: PA3041
    PA3041
Thanks for the reply
I found it form gem polish machine which control 110v small DC motor. Motor does not use much load but the polisher that connected to the motor shaft.
The input voltage is 230v and the resistor is used to reduced to the 110v and rectified using single diode and smooth capacitor.
--- Updated ---
Thanks , I put a post on their Facebook page
