Amr Wael
Member level 5
Hello ,
I am designing a circuit for controlling the phase angle (Firing angle) of a TRIAC. I don't want to use a microcontroller.
I am have a circuit that generates a PWM signal. I want to design a circuit that introduces a variable phase shift to this PWM signal from 0 to 180 degrees for example
, this variable signal is going to be the control signal of the TRIAC.
I found many ways but all of them use zero cross detection and a microcontroller to adjust the firing angle.
I just want to do it in analog way. I Tried using an All-pass filter that worked perfectly for shifting Sinusoidal signals but it didn't work when phase shifting a square signal .
My AC source frequency is just 50 Hz so the firing pulses need to be the same frequency.
Thank you very much in advance.
Best Regards ,
Amr Wael
Best Regards ,
Amr Wael
