That's a cable shieldwhat is the name of this element in the datasheet?
I´d say it shows the shield of a shielded wire.
Not 100% sure about this.
Klaus
thank you guys,That's a cable shield
that's it.I've never seen that on a PCB. Maybe it indicates a shielded trace? Where did you get that?
As already said: it is no component, just a single connection.but as you can see in the image, voltage is characteristic of this component. I do not know whether it is the voltage of 25uF capacitor or voltage of the undefined element? for other capacitors, it does not define any voltage in the characteristic.
