Some details of data processing - how to implement
FlyingDutch
Advanced Member level 1
Bydgoszcz - Poland
Hello Guys,
i have one issue with VHDL code. The prooblem is related to multiple drivers. I have in some place of my code such fragment (VHDL):
   PROCESS (lpc_en, lclk)
   BEGIN
      IF (lpc_en'EVENT AND lpc_en = '1') THEN
        cycle_cnt <= cycle_cnt+1;
        IF (cycle_cnt >= 8) THEN
          cycle_cnt <= 1;
          sendPackage  <= '1';
          IF (packageNumber = 1) THEN
            packageNumber <= 2;
            package2Send <= 1;
          ELSIF (packageNumber = 2) THEN
            packageNumber <= 1;
            package2Send <= 2;
          END IF;
          -- zapisz do BRAM ostatni cykl + wyślij 8 poprzednio zapisanych
        ELSE
          -- tylko zapisz do BRAM ostatni cykl
          sendPackage  <= '0';
        END IF;
          addrAbufU <= to_unsigned(((packageNumber-1)*8+cycle_cnt-1),addrAbufU'length);
          addrAbuf <=  std_logic_vector(addrAbufU); --adres zapisu w BRAM
          lpc_addrBuf <= lpc_addr;
          lpc_data_inBuf <= lpc_data_in;
          --wykonaj zapis do BRAM pod wskazany adres
          saveCycle <= '1';
      END IF;
   END PROCESS;
In this process i am setting saveCycle <= '1'; - which means that there is need to write last data chunk to BRAM memory. And in next process I am checking this signal saveCycle and if it is equal '1' I am writing data chunk to BRAM - see code:
   PROCESS (lclk, lreset_n) --save current cycle in BRAM
   BEGIN
      IF (NOT lreset_n = '1') THEN
         cnt2 <= b"0000000000000";
      ELSIF (lclk'EVENT AND lclk = '1') THEN
         IF (saveCycle = '1') THEN --trzeba zapisac aktualny cykl do BRAM
             if (cnt2 = 0) then
                cnt2 <= cnt2 + 1;
              elsif ((cnt2 > 0) and (cnt2 < 10)) then
                 cnt2 <= cnt2 + 1;
                 enaB <= '1';
                 weaB <= "1";
                 dinAbuf(31 downto 28) <= "0000";
                 dinAbuf(27 downto 12) <= lpc_addrBuf;
                 dinAbuf(11 downto 4) <= lpc_data_inBuf;
                 dinAbuf(3 downto 2) <= "00";
                 dinAbuf(1 downto 0) <= std_logic_vector(cycle_type);
              elsif ((cnt2 >= 10) and (cnt2 < 14))  then
                 cnt2 <= cnt2 + 1;
                 weaB <= "0";
                 saveCycle <= '0';
              end if;
         END IF;
     END IF;
   END PROCESS;
After saving data to BRAM I set saveCycle <= '0'; in order to not save data to BRAM next time. But this cause error:
[DRC MDRV-1] Multiple Driver Nets: Net saveCycle has multiple drivers: saveCycle_reg__0/Q, and saveCycle_reg/Q.
Could I ask more experienced colleagues to advice me how to properly organize such data processing?
Thanks in advanvce and regards
The worst idea is using two clocks in your design, lpc_en and lclk. That will hardly synthesize to useful FPGA hardware. Instead use lclk as clock for all processes and lpc_en as clock enable (provided it's in the same clock domain, otherwise generate a synchronized signal). All writes to save_cycle have to occur in one process.
Consider that save_cycle represents a FF, your code needs to follow the VHDL template for register inference.
    FlyingDutch
i haven’t looked at your code that closely, but it appears to me that this could all be done a little more elegantly if you used a state machine.
Hello @barry,
I has rewritten this code. I place all this code (as suggested by @FvM) in one bigger process. After making simulation of this circuit I can say that it now works OK.
BTW: the state machine is implemented in part I didn't show.
Thanks and Regards
In addition to FvM's observations, I would suggest you start by somehow merging both process statements together. The actual issue with the multiple drivers error is because you are making assignment to the same signal in different processes.
read post #4.
